1998 Other Saturn Models RPM spike then Stall
1998 SATURN
87,000 MILES • 4 CYL • FWD • AUTOMATIC
KERIKKRESTIN
When I slow down for a stoplight/sign ect. my engines RPM spikes to around 2.5k then drops to around7-800 causing it to sputter and stall. Also my engine makes a loud rattling sound that only goes away when i reach 4k RPM but quickly returns once the trany shifts gears
Jun 26, 2008 at 10:05 PM
WHOALAZYEYE
i drive a 2000 saturn sl2, my car spikes while downshifting but doesn't stall out. every mechanic says its normal but yet they can't give me a reason why it is doing so. i was looking at other forums and the best solution that i am going to try is to have the computer reprogrammed to correctly regualte the automatic transmission. if you have any other ideas let me know. :]
ps. your rattling may be the variable tumble control system plates ar closed in the intake manifold because its happening at those rpms. try replacing the vtcs valve.
Jun 27, 2008 at 5:31 AM
KERIKKRESTIN
thanks, i think i found out what was wrong with it i hope, currently my local car doctor is looking at it. the timing chain decided to go and put a hole in the valve cover. so hopefuly after all is said and done it works a hell of a lot better
Jun 27, 2008 at 5:05 PM
