1998 Other Saturn Models RPM spike then Stall
KERIKKRESTIN
  • 1998 SATURN
  • 4 CYL
  • FWD
  • 87,000 MILES
When I slow down for a stoplight/sign ect. My engines RPM spikes to around 2.5k then drops to around7-800 causing it to sputter and stall. Also my engine makes a loud rattling sound that only goes away when I reach 4k RPM but quickly returns once the trany shifts gears
Friday, June 27th, 2008 AT 5:05 AM
WHOALAZYEYE
I drive a 2000 saturn sl2, my car spikes while downshifting but doesn't stall out. Every mechanic says its normal but yet they can't give me a reason why it is doing so. I was looking at other forums and the best solution that I am going to try is to have the computer reprogrammed to correctly regualte the automatic transmission. If you have any other ideas let me know. :]
ps. Your rattling may be the variable tumble control system plates ar closed in the intake manifold because its happening at those rpms. Try replacing the vtcs valve.
Friday, June 27th, 2008 AT 12:31 PM
KERIKKRESTIN
Thanks, I think I found out what was wrong with it I hope, currently my local car doctor is looking at it. The timing chain decided to go and put a hole in the valve cover. So hopefuly after all is said and done it works a hell of a lot better
Saturday, June 28th, 2008 AT 12:05 AM
