1998 Other Saturn Models I need help
1998 SATURN
148,000 MILES • 4 CYL • FWD • AUTOMATIC
EMALDO1004
my car won't pass smog in CA, they said I need to replace the o2 sensor and transmission temp sensor, what is easier to replace and where is the o2 sensor located?
Jul 22, 2008 at 7:14 AM
MERLIN2021
  • 17,250 POSTS
If your check engine light is on, and both codes are stored, they will not pass you until the car can pass it's own emissions readiness...you will have to change both, the O2 sensors are in the exhaustm one before the converter, and one after, to look up the other, I need the engine size and vehicle model...
Jul 22, 2008 at 7:21 AM
