1997 Saturn SW1 Electrical Problems
1997 SATURN
BDUP73
  • 5 POSTS
I have a 1997 Saturn SW1 with a 1.9L SOHC and 125,000 miles. Recently it has begun to have electrical problems. Sometimes when I apply the brakes all of the electical instruments inside the car (radio, lights, speedometer, tachometer, gas gauge, etc.) go off and come back on again. This also happens when I have the headlights on andswitch the high beams on or off. Other electrical issues are beginning to show themselves too, like flickering lights when I apply the brakes or put on a turn signal. Sometimes when I apply the brakes the lights come on brighter. Could this be the alternator (I hear that they often go bad on higher-milage Saturns) or is it a bad gound or something? Also, when my car is started and I release the parking brake the car shuts off until I pop the hood and fiddle with the battery cables. Is this related. And insight you have would be greatly appreciated. Thanks
Mar 4, 2007 at 4:48 PM
BRUCE HUNT
  • 3,754 POSTS
I take it you have not had this running since the new motor was put in?
Dec 29, 2006 at 8:00 AM
COLORADOFLOWER
No, the car has not ran since new engine was put in.
Dec 30, 2006 at 4:10 AM
2CARPRO JACK
  • 11,533 POSTS
Alll battery connections need to be clean and tight first of all.Then have the alternator and battery tested.
Mar 4, 2007 at 11:15 PM
Suggested Repair
Clean and tighten all battery connections, then have the alternator and battery tested.
Conversation Summary
The owner of a 1997 Saturn SW1 reports instruments and lights cutting out when braking or switching high beams, flickering lights, and stalling after the parking brake is released until the battery cables are adjusted. The advice is to clean and tighten all battery connections first, then test the alternator and battery.
