1997 Other Saturn Models Stalling
1997 SATURN
130,000 MILES • 4 CYL • FWD • AUTOMATIC
BRADICUS
The Saturday that just passed, my car died while I was driving. I pushed it into a parking lot and checked under the hood. My belt tensioner was shot. I had the Canadian Tire across the street fix it for me and now the car is stalling out and the check engine light is coming on due to some "cam sensor" that isn't there. Now the mechanic is charging me another $400 to clean and readjust the throttle body and says the sensor will cost another $500 at least. Any of this sound off to anyone else? The car is a 1997 Saturn SL1, automatic. I've got a little bit of knowledge when it comes to the mechanical side of life and something about this isn't sitting right. Just curious if I'm getting hosed.
Mar 4, 2008 at 8:12 AM
MASTERTECHTIM
  • 4,750 POSTS
put on your coat, it sounds like your getting hosed. what codes do you have?
Mar 4, 2008 at 8:18 AM
BRADICUS
never found out the codes
Mar 4, 2008 at 8:56 AM
MASTERTECHTIM
  • 4,750 POSTS
i have seen these throw cam codes. what the problem is usually replacing the ignition module and ignition coils solves it. hope this helps
Mar 4, 2008 at 9:13 AM
