1997 Other Saturn Models Won't crank
1997 SATURN
200,000 MILES • 4 CYL • 2WD • MANUAL
GARNIE311
'97 Saturn SC1 w/ 4 cylinder, occasionally will not crank. If push-started, it runs great. Battery and charging system is working fine. Most times, it cranks and starts fine.
Could it be the ignition switch?
May 27, 2008 at 6:28 AM
LEGITIMATE007
  • 5,121 POSTS
yes . it could be poor connections also. corroded , connection at the starter. these are all things that have to be checked.
May 27, 2008 at 7:07 AM
