1997 Other Saturn Models 2 car windows intermit work and doo
1997 SATURN
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
SABRINACAR
I have a SL1 that suffered water damaged supposidly from the sunroof. The passenger window doesn't always roll up or down, acts like it's stuck or not responding but if I keep trying it works, then the passenger rear window rolls down but not up?
My door locks are totally dead due to some missing switch the previous owner removed because they kept locking and unlocking randomly..any idea what it was?
And if the driverside lock is loose on the outside, does a locksmith do that, the part where you put your key in pushing inside a bit almost looks like there is no key entry at times?
Sep 1, 2008 at 4:45 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Do the windows work at the door switch or is problem there if you operate from the master as well as door?
Door locks probably took fuse/relay out.
Loose door lock can be tightened by removal of door panel and inspecting. Also if lock is loose that could be causing door locks to random lock.
Did water get in the switches?
Let me know
Thanks for donation
Sep 2, 2008 at 5:03 AM
