1996 Other Saturn Models Water pump
1996 SATURN
100,000 MILES • 4 CYL • FWD • AUTOMATIC
KVT579
I am trying to locate the water pump. I am being told by a local shop that it is leaking anti freeze. Judging by the hoses I think it is on the passenger side under the air comp. Is it easy to get at to Rand R?
Apr 19, 2008 at 7:21 AM
JUSTIN FREED
  • 87 POSTS
Unfortunately, Saturn engineers apparently decided that they wanted DIY'ers to get really dirty and frustrated when working on their cars.
Get yourself a Chilton's manual (or comparable) and it will really help you in many ways.
As for the water pump, it IS located under the air compressor. You can either remove the air compressor (actually, DO NOT remove the compressor but disconnect it from the engine and move it aside. DO NOT disconnect any hoses).
Or, you can jack up the car, remove the splash shield from the passenger side wheel well and access the water pump that way (that's my preference).
Good luck!
Apr 20, 2008 at 2:01 PM
