1996 Other Saturn Models not shifting
1996 SATURN
13,085 MILES • 4 CYL • 2WD • AUTOMATIC
PE067228
has trouble codes
0732 0733 0734
also 1406
the 1406 i think is a problem with the EGR can this cause iratic shifting?
Apr 25, 2010 at 9:18 AM
SATURNTECH9
  • 30,869 POSTS
[quote:06d5b52e7f="pe067228"]Transmission problem
1996 Other Saturn Models 4 cyl Two Wheel Drive Automatic 13085 miles
has trouble codes
0732 0733 0734
also 1406
the 1406 i think is a problem with the EGR can this cause iratic shifting?[/quote:06d5b52e7f]
ur egr valve is not going to set a incorrect 2nd 3rd and 4th gear codes thats for sure.its most like a pressure issue.u usually dont loose 3 gears like that all at once unless its a electrical or pressure issue.how does the car shift?let me know.
Apr 25, 2010 at 4:17 PM
