1996 Other Saturn Models iM confused
WHIPKITTY
  • 1996 SATURN
  • 4 CYL
  • FWD
  • 128,000 MILES
My saturn wont start, starter hits hard motor will not turn over even when I tried pull starting it
Saturday, December 22nd, 2007 AT 9:03 AM
JUSTIN FREED
  • 87 POSTS
I would try to rotate the engine by hand using a wrench on the crankshaft pulley bolt. Disconnect the battery first just to make sure nothing is electrically stuck. Make sure the transmission is in neutral or at least free-spinning.
Engine should rotate quite freely. If it doesn't you should ensure tranny is in neutral by bypassing Brake Bypass Interlock switch and try rotating engine again.
If it doesn't rotate this time, be prepared to find out you have a seized engine (specifically what, who knows).
Remember, this is just an educated guess based on limited info. Hope it helps.
Saturday, December 22nd, 2007 AT 10:09 AM
