1996 Other Saturn Models help
1996 SATURN
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
KIMP124
Hi today when I tried to start my car, it showed the service engine light and also key was stuck at first. got key out and put back in, car making light clanking noise from engine area. wont start on first try. has oil and gas in it. the car has been touchy with door locks for a long time, you have to make sure the door lock button is in certain place when locking door or it will continue a clicking noise. I dont know if this has anything to do with the current problem, but wanted to give you that backround info if it does . thank you very much for your help
Jun 3, 2010 at 12:52 AM
SATURNTECH9
  • 30,869 POSTS
[quote:4d613e60ea="kimp124"]Electrical problem
1996 Other Saturn Models 4 cyl Two Wheel Drive Automatic 120000 miles
Hi today when I tried to start my car, it showed the service engine light and also key was stuck at first. got key out and put back in, car making light clanking noise from engine area. wont start on first try. has oil and gas in it. the car has been touchy with door locks for a long time, you have to make sure the door lock button is in certain place when locking door or it will continue a clicking noise. I dont know if this has anything to do with the current problem, but wanted to give you that backround info if it does . thank you very much for your help[/quote:4d613e60ea]
You need to replace that door lock switch it could draining your battery.I would also have a new key made at saturn don't copy the old worn out one and see if that fix's your not being able to turn the key some time's.With your service engine soon light go to a auto parts store like autozone have them scan your car for codes if you have any bring me back the numbers.After you get the codes then have them test your battery and alternator.Let me know what you find.
Jun 3, 2010 at 6:10 AM
