1995 Other Saturn Models over heating
TOYOTA58
  • 1995 SATURN
  • 4 CYL
  • FWD
  • 110,000 MILES
How can I be sure if I have a blown head gasket I don't have any water in my oil and how complicated is it to fix
Saturday, March 8th, 2008 AT 9:16 AM
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat, Pressure test the Rad. Cap, Clogged radiator, Fan clutch, Radiator electrical fan, collaspe hoses, water pump.
Sunday, March 9th, 2008 AT 5:10 PM
