1993 Saturn SL2 Stalling and Fuel Smell
1993 SATURN
CPRITCHARD
i have a 1993 saturn that is stalling out constantly and you can smell fuel could this be a sensor problem? and if so which sensor would you start with? :( :( :(
Apr 26, 2006 at 2:42 PM
PEPPERMRJ
  • 1,158 POSTS
Could be a fuel leak. For safety check all fuel lines, filter, and connections.
What maintenece has been done? Plugs, wires, PCV valve, etc? Might just need a tuneup. Run a tank of fuel; injector cleaner thru also. I like chevron with techron myself.
Good luck and let us know. :)
Apr 27, 2006 at 1:43 PM
Suggested Repair
Inspect fuel lines, the fuel filter, and all connections for leaks. Review basic maintenance such as plugs, wires, and the PCV valve, and consider a tune-up plus a tank of fuel injector cleaner.
Conversation Summary
The owner of a 1993 Saturn SL2 with 180,000 miles reports constant stalling and a fuel smell and asks whether a sensor is at fault. The expert says a fuel leak is possible and recommends checking fuel lines, the filter, and connections, reviewing maintenance, and trying a tune-up with injector cleaner.
