Wipers stop working
1993 SATURN
PIPPY
  • 18 POSTS
Four cylinder front wheel drive automatic
checked number six fuse 25 amp okay. hear humming noise when turn wipers on, but they will not work. please help.
May 18, 2008 at 7:15 AM
1993 SATURN SL1
I had a similar problem. Was not electrical. It was the nut that mounts the wiper transmission arms to the motor, it had come loose. Also, the transmission arms were seized with rust which is why the nut came loose to begin with. I went to the salvage yard and got the transmission system for $75.00 instead of the $400.00 Saturn was asking. It took some doing but, with the help of the Haynes manual managed to replace it myself ( i am not mechanically inclined)
If it is not the wiper motor, which i went through too (sounds like it is not)
It involves removing exterior the wiper cowling from below the windshield (got fiddle with the hood up and down when pulling this off.)
On the right hand side there will be a whole that Leeds under the dash area, this is where the wiper motor is. You will see the nut and wiper arm transmission, careful that the swing arm is in the 9:00 position before tightening the nut or your wipers will not cycle properly.
May 20, 2008 at 3:03 PM
AWILLIAM
Are there any known common failures that would stop the front wipers from working?
Is there a fuse? If so where might I find one. This is my daughters car and she can not afford a major expense.
Suggestions?
Jan 13, 2017 at 8:22 AM (Merged)
DODGE89
  • 33 POSTS
it could be a fuse, the fuse will be with the fuse box. usually under the drivers side dash? not quite sure. if its not a fuse then the motor for the wipers went. it does not cost too much if you get it from a junk yard. this should be a easy/cheap fix. either way.
AWILLIAM
Problem turned out to be the the nut on the drive motor came off and the linkage popped off. Just had to reattach it.
Thank you
DARTSDUNE
Hello, was driving (in the rain) today and my wipers stopped working. the driver's side wiper stopped in the middle of the windshield, and the passenger went do to the off position. I can move the driver's side wiper with just my hand across the windshield, but the passenger will not move.
Any ideas?
PEPPERMRJ
  • 1,158 POSTS
Something in the linkage came apart.
PIPPY
  • 18 POSTS
Four cylinder front wheel drive automatic 12,200 miles
wiper will not work. please help!
  • 31,937 POSTS
Hi there, Check fuse number six first (25 Amp) Mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_fuse_2.jpg
PIPPY
  • 18 POSTS
where is the diagram for fuses located the one showed me is not under hood maybe driver side dashboard? let me know exactly and is it easy to access.
PIPPY
  • 18 POSTS
Four cylinder front wheel drive automatic 122,000 miles
wipers just stop working while car was parked running sounds like can here motor when turn on moves by hand pretty easy, but when turn on will not work. please help.
PIPPY
  • 18 POSTS
cannot open private message. can you help?
