1993 Other Saturn Models electrical?
1993 SATURN
140,000 MILES • 4 CYL • FWD • AUTOMATIC
SPANKYLEC
the only way the car will start is if jumped. it will stay running when started, but when you hit the brakes, the dash lights will flashon and off alot. i have checked all grounding.
Mar 26, 2008 at 7:05 PM
SPANKYLEC
[quote:b360fb0d1a="spankylec"]Electrical problem
1993 Other Saturn Models 4 cyl Front Wheel Drive Automatic 140000 miles
the only way the car will start is if jumped. it will stay running when started, but when you hit the brakes, the dash lights will flashon and off alot. i have checked all grounding.[/quote:b360fb0d1a] :?:
Mar 26, 2008 at 7:07 PM
CHRISSER
I have a 94 Saturn and have had electrical problems from the start. When my car starts acting crazy and doing what yours is doing--flashing lights with brake pressure and other things; I disconnect the battery cables and then connect them. This reboots the electrical system. I got this answer many years ago on Yahoo Groups from a Saturn technician in Houston.
Mar 27, 2008 at 11:51 AM
