My cooling fan is not engaging. I replaced the coolant temp sensor, the relay, and pulled the fan, hooked it up to the battery and it turns on. I guess there must be a bad ground wire in there somewhere. can I just run a direct ground from the fan to the engine and see if that solves the problem, or would this effect other electrical systems?
Jun 2, 2008 at 12:23 AM
