1992 Other Saturn Models timing chain cover removal
1992 SATURN
181,349 MILES • 4 CYL • FWD • AUTOMATIC
METHODMAN390
im just anting to find out.do i have to remove the valve cover to remove and reseal the timing chain cover gasket on my 1992 saturn sl1 with a 1.9l sohc engine and will i lsoe much oil.
Oct 7, 2008 at 3:00 AM
TETRA021
  • 15 POSTS
yes, you will have to remove the valve cover. but if you plan to take off the timing chain cover, you will need a special oil seal replacement tool SA9104E or equivalent to retain the crankshaft timing sprocket to prevent damage to the timing chain guides.
Nov 5, 2008 at 2:50 PM
