2006 Saturn L300 will not exceed 30mph,
2006 SATURN L300
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDREWHOWARD
Engine bogging, loads up & hesitates when accelerating, followed by engine pinging noises.?????? Whats wrong?
Oct 3, 2010 at 12:43 AM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Oct 3, 2010 at 1:07 AM
