2003 Saturn L300 Loss of Engine oil
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
LQ0608725
I have a saturn L300 that is lossing oil lossing coolant, some mechanic said that its transmission fluid in the antifreeze and said there is no water in the engine but he also said that the problem that i was having was a blown radiator so i replaced the radiator and have the same problem.
Oct 3, 2010 at 12:11 PM
SATURNTECH9
  • 30,869 POSTS
So do you have motor oil in your coolant?Or transmission fluid in your coolant?The only way i can see transmission fluid getting in your coolant is thru the transmission cooler in your radiator.Let me know.
Oct 3, 2010 at 3:16 PM
