2003 Saturn L300 instrument cluster
TOM MCARTHUR
Computer problem
2003 Saturn L300 6 cyl Two Wheel Drive Automatic
intermtent working gauges mostly don't work, come on momentarly while driving but mostly don't work. all guages effected includding speed, and rpm.
also warning indecator light go on and off, but mostly on while driving. ie check eng, service eng, abs, air bag, oil, water charging and some i don't recognize. this problem started after have the brakes replaced may not be related. other then the lights and guages the car run fine.
Feb 22, 2009 at 5:37 PM
H2ERK
I've been driving it this way for over 9 months without any other problems with the 160,000+ car. What is odd is that sometimes none will work and other times some will work while the others aren't.
Nov 5, 2010 at 5:23 AM
