My fuel gage registers "F" all the time when car is running. Drops to "E" when off. How easy/expensive is this to fix?
Oct 5, 2008 at 8:34 AM
✓Experienced Mechanic
Hi it sounds like you have a gas sender that is bad, the fuel tank must be reomved to replace it. Cost should be between 200.00 and 600.00 depending if the dealer services the gauge separate from the fuel pump
Nov 14, 2008 at 7:27 AM
