2001 Saturn L300 traction control
2001 SATURN L300
JSTENE
Steering problem
2001 Saturn L300 6 cyl Front Wheel Drive Automatic
after jacking the rear of the car up to change the fuel pump, the traction control light will only stay on when first started after that it goes off and the traction control is not working?
Aug 28, 2010 at 1:33 AM
SATURNTECH9
  • 30,869 POSTS
Your going to have to go to a shop and have your abs code's read to see what that code number's are.Let me know the number's are.I would also check the rear wheel speed harness to both rear wheel's and make sure you didn't damage them when you jacked up the rear end since this all happened since you jack the rear end up.
Aug 28, 2010 at 4:29 AM
