Electrical problem
2001 Saturn L300 6 cyl Two Wheel Drive Automatic 49k miles
Hi, I have a non-running saturn, that was running great til I tried to wire in a generic 02 sensor. I had a p0050 code (02sensor pre-cat heater) found out that this is not a 02 sensor, but a air/fuel sensor (has 5 wires all different colors), I guessed at wiring the generic 02 sensor (4-wire) to it ( this was before finding out that I was dealing with a A/F sensor) , the car started, ran rough, barely made it back into the driveway. I bought a used but correct A/F sensor,installed it, car will not even start now. Getting other codes now (EGR, throttle position etc). Do you think I could have fried the ECU just by wiring a 02 sensor incorrectly? thanks.
May 21, 2009 at 4:28 AM
