2001 Saturn L300 ECU will not communicate with code reader
WILLIAM MILLER
Electrical problem
2001 Saturn L300 6 cyl Front Wheel Drive Automatic
Helping a friend.
Car wouldn't start. Independant shop said the ECU was dead because it would not communicate with code scanner. CEL is on.
I confirmed yesterday with my OBDII code reader.
Is the engine computer called an ECM, PCM, ECU or what? Where is the unit located in the car? We found a unit under the cowl on the passengers side. It was manf by seimens. This does not match what we are finding on the internet. Where can I get an accurate picture and part number?
If we find a good used unit, will it run the car?
Will it need to be reprogrammed at the dealer?
Is there a cross reference to other GM cars where this same computer was used?
Thanks!
Apr 10, 2010 at 2:09 AM
SATURNTECH9
  • 30,868 POSTS
It's called a ECM it's on the driverside on top of the intake tube it's silver it has four reverse torxs holding it down with two larger connectors on it that are side by side.if u get a compatible ECM it will start after u relearn the passlock sensor.u might have to get it programed we will play it by ear .let me know when u find it.
Apr 10, 2010 at 4:02 AM
WILLIAM MILLER
We found the part and have it in our hands!
Here are some numbers:
0261204591 (This looks like a Bosch number. Could it be?)
24443937
also : uo08900238
These are found on a sticker on the top of the module that has a GM symbol and CH
On the edge if the module there is another sticket with: 97208404591
These are the numbers that are large enough to see.
Which numbers are important to try and find a replacement?
Apr 17, 2010 at 1:41 AM
SATURNTECH9
  • 30,868 POSTS
the part number u need is 9153242 i dont know where the number on the ecm is i never paid attenion the part number on them just the ones on the box the came in.it looks like 2000-2005 v6 are all that part number.let me know when u get one and its commucating and i will give u the instructions on learning the pass lock sensor.let me know.
Apr 18, 2010 at 8:49 AM
WILLIAM MILLER
Do you have a source?
Apr 18, 2010 at 11:48 AM
SATURNTECH9
  • 30,868 POSTS
No I don't have source I was talking about when I worked for Saturn I used to get them from the parts department.I worked for Saturn for over 16yrs.the new ECM is like 640 and will have to get it programed at the dealer.what I would do is look for one on eBay they have tons of them u just have to sort thru them all.I put in Saturn ECM in the search and got over 1,000 came up.they probably even have some new ones on there from closed dealers.but if u get a used one then all u will have to do is learn the pass lock and it will start.let me know when u get one and I'll help u out with that.
Apr 18, 2010 at 1:50 PM
CRYSTAL GODDARD
So I have a 2003 Saturn LW300 with the 3L in it. The motor cooked due to a tension pulley......so replaced the motor....matched with registration #'s. Got everything back together and started the car. It run for a few minutes....could rev it up couldn't drive it due to we hadn't put the axles back in. Just wanted to make sure it run. Had a break....put tires and axles and etc on and started it again....this time gauges went all crazy, bogging out, and wouldn't take fuel.....I went all over all the connections and wiring. Plugged a computer into it and there's no communication.....took it to the dealer and they said a ECM. Got one.....still NOTHING. Paid them 400$ to tell me they didn't know and did everything we had already done......there is power all the way to the ECM but nothing between the ECM and the computer port.....any suggestions?
Oct 25, 2016 at 5:59 AM
