2001 Saturn L300 computer error
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
FASTEDDIE47
i pulled some codes from my car.
Trouble Code: P1779
Engine Torque Delivered To TCM Signal
Trouble Code: P1791
Throttle Pedal Position Signal Malfunction
Trouble Code: P0118
ECT Sensor Circuit High Input (Low Temperature)
Trouble Code: P0123
TP Sensor Circuit High Input
Trouble Code: P0223
Throttle Position Sensor 2 Circuit High Input
i replaced the ECM thinking that was it but no go, I will be greatful for any help
Jul 21, 2009 at 11:10 AM
BRIAN 1
  • 1,030 POSTS
The engine control module (ECM), transaxle control module (TCM), and the body control module (BCM) communicate with each other over the controller area network (CAN) BUS circuits 2500 and 2501. The CAN BUS is a communications protocol that is used by the TCM to communicate vital engine control inputs from a stand-alone engine controller. The diagnostic checks the information received in CAN to determine whether to pass or fail a code. Before checking the information, the TCM makes sure the CAN messages are being received by checking the BUS failure timer.
Conditions for Setting the DTC
DTC P1779, P1791, P1792 or P1795 will set if the TCM did not receive a needed engine parameter over the CAN BUS from the ECM when:
• Engine speed is greater than 500 rpm for 5 seconds and not at fuel cutoff.
• System voltage between 8 and 18 volts.
Diagnostic Aids
• This code does not indicate a problem with the TCM. It does indicate the ECM is not sending the required information to the TCM.
• Check for and diagnose any DTCs stored in the ECM related to the ECT, pedal position or TP sensor circuits.
• Check for any DTCs stored in the EBTCM related to the torque reduction/request circuit.
what made you think it was the ECM? and why did you replace it? did all these codes appear before or after ECM replacement?I would also check for pin tension at the ECM,and any bent or corroded terminals.post back and will go to the next step.
Jul 21, 2009 at 1:31 PM
FASTEDDIE47
i replaced the ECM after testing as best i could and reading some info i got off the net. i have just a busic scantool and volt meter.
this is the info i got off the net.
Trouble Code: P1779
Possible Causes:
Perform an Onboard Diagnostic System Check of the PCM
The PCM is not sending the required information to the TCM (the problem is not related to the TCM)
Check for any trouble codes related to the CAN data bus
PCM has failed
Trouble Code: P1791
Possible Causes:
PCM has failed
Trouble Code: P0118
Possible Causes:
ECT sensor signal circuit is open between the sensor and PCM
ECT sensor signal circuit is shorted to VREF (5v)
ECT sensor is damaged or it has failed (it may be open)
PCM has failed
TSB 01-06-04-005 contains a repair procedure for this code
Trouble Code: P0123
Possible Causes:
TP sensor connector is damaged, open or shorted
TP sensor signal circuit is shorted to VREF (5v)
TP sensor ground circuit is open between the sensor and PCM
TP sensor is damaged or it failed (it may be open)
PCM is damaged or it has failed
Trouble Code: P0223
Possible Causes:
TP2 sensor signal circuit is shorted to VREF
TP2 sensor ground circuit is open
TP2 sensor is damaged or it has failed
all but one code came back when i replaced the ECM
Trouble Code: P1271
Accelerator Pedal Position Sensor 1-2 Correlation
Possible Causes:
APP sensor connector is damaged, open or shorted
APP sensor assembly is damaged or it has failed
thank you for your help
Jul 22, 2009 at 4:55 AM
BRIAN 1
  • 1,030 POSTS
follow this for code p1271,To locate an intermittent problem, use the Scan tool to monitor APP SENSOR 1 and APP SENSOR 2 with the ignition On, engine Off and:
• Accelerator pedal at normal rest position.
• Accelerator pedal pressed completely to floor
Voltage should be within 0.1 volts of:
Rest
Accelerator Pedal to Floor
APP SENSOR 1
0.40
3.80
APP SENSOR 2
0.20
1.90
If no other DTCs have been set and the voltage readings are not as indicated above, replace APP sensor assembly.
If both P1271 and P1516 are set, circuit 486 or 1274 may be shorted to voltage.
If DTCs P0102, P0108, P0533 and P1271 are set, there may be a short to voltage on circuit 1164.
If DTCs P0103, P0108, P0113, P0118, P0123, P0223, P0341, P0406 and P1271 are set, there may be an open circuit in the 5-volt reference return circuit 652.
Jul 22, 2009 at 10:53 AM
