2000 Saturn L300 throttle position sensor
TAMARA9977
Electrical problem
2000 Saturn L300 6 cyl Front Wheel Drive Automatic
where is the throtle position sensor on my vehicle?
Jan 28, 2009 at 9:30 AM
  • 75,988 POSTS
Simlar to other Saturn TPS location
https://images.2carpros.com/forum/automotive_pictures/12900_tps_17.jpg
Jan 28, 2009 at 9:43 AM
TAMARA9977
My car has a DOHC. There isn't a throttle cable, in stead I have a sensor on the gas peddle and a motor on the throttle body.
While I am driving my car will suddenly stop responding to the gas peddle. The Rpm's will drop and I start costing. If I turn the engine off and restart it I can go for another mile or so and then the same thing happens. i am getting the following engine codes.
P1271 - Accelerator Pedal Position Sensor fault
P0101 - Mass air flow error - Auto Zone Ticket describes a possible TPS problem
P0403 - EGR - I know this went bad
P0405 - EGR - Same
P0341 - Camshaft position sensor out of range
P0107 - MAP Sensor error
I think I got some incorrect info about the TPS. Do you have any suggestions?
Thank you for the help
Jan 28, 2009 at 10:05 AM
  • 75,988 POSTS
Clean and test the EGR valve and recheck the TPS
Jan 28, 2009 at 10:57 AM
TAMARA9977
Thank you for your response.
The bolts that hold the upper part of the EGR valve to the base broke a few months back. At that time I replaced it with an EGR valve from a salvage yard as I needed my car to get to school and no place in town had a new one.
Thank you for the suggestion. I'll try cleaning the salvage EGR good before I give in and pay $250 for a new one.
What is the best way to test the Accelerator Pedal Position Sensor? I believe it's the small motor/cylinder looking device hooked to the accelerator pedal. Is that correct? Can I test it with a ohm meter?
Thank you again you have been most helpful
Jan 28, 2009 at 11:59 AM
  • 75,988 POSTS
At closed throttle position it should read 0.3 volts and wide open throttle at 4.6volts
Jan 28, 2009 at 2:58 PM
