2003 Saturn L200 Wiper Motor
141,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHET369
When I switch on the windshield wipers the water pump works, but wiper motor doesn't. How do I get to the wiper motor to unplug the wiring harness to it and check to see if current is coming to it? This is the only way I can figure out to find out if it is the switch or the motor. Or do you have another way for me to check this out?
Sep 14, 2010 at 8:46 AM
KHLOW2008
  • 41,812 POSTS
Hi Chet369, Thank you for the donation. The diagram shows the location of the wiper wire connector, Item # 11.
https://images.2carpros.com/forum/automotive_pictures/192750_WireConnectors03SaturnL200Fig04_1.jpg
Wiper system is linked to the Body Control Module and trouble codes can be retrieved with the aid of a scanner. Try retrieving for trouble codes first, it can save you a lot of guess work and time. To access the wiper motor, the wiper arms, hood seal and air inlet grill has to be removed.
Sep 16, 2010 at 5:32 AM
