2003 Saturn L200 Will turn over strong, will not start, do
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
RMIRCOV
Engine will turn over strong, yet will not start. I do not smell gas. Is it a timing belt issue, maybe jumped a bit?
Dec 1, 2008 at 9:58 AM
ROADSTER1929
  • 16 POSTS
maybe a fuel pump or your not gettin any fire
coil,plugs,plug wires
Dec 1, 2008 at 10:12 AM
  • 75,988 POSTS
Do you hear the fuel pump come On when key at run position? If so
Check the fuel pressure with a fuel pressure gauge designed for your fuel system make sure its within specifications and comeback with the readings this is where we start.
Dec 1, 2008 at 10:14 AM
