2003 Saturn L200 struts
51,000 MILES • 4 CYL • FWD • AUTOMATIC
LEHALT
Do you need special tools to replace front struts? We have a rattle coming from the front end and believe it maybe the struts. Do you replace both struts and mounting brackets or just the struts? Any advice would be greatly appreciated.
Thanks Lloyd Ehalt
Mar 30, 2008 at 8:52 AM
LEGITIMATE007
  • 5,121 POSTS
you should be able to use all of the hardware from the old struts to do the job. after all that car is only a couple of years old. but you may find yourself with the same problem after replacing the struts. so look good at the whole area where you think the ratttle is coming from. I had a jingle coming from a car that i did, and found out it was the sway bar linkage all they needed was to be tightened a little. I mean this sound was big I thought something serious was about to happen. get my point? just so you know.
Apr 29, 2008 at 10:02 PM
