2003 Saturn L200 How do I get my car started
2003 SATURN L200
117,788 MILES • 4 CYL • 2WD • AUTOMATIC
FLYING4JESUS
I recently changed my fuel injectors to correct an rough idling problem. I used a chilton manual and since I replaced them I cannot get fuel pressure and fuel into the cylinders. I have check the fuel pump and it is pumping fuel and the fuel rail is also receiving fuel but no fuel pressure is building up. I have bled the system to my best ability but I cannot figure out what the problem is and I am hoping that you have some suggestions.
Mar 8, 2009 at 10:56 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:11e69e56d3="flying4jesus"]Engine Mechanical problem
2003 Saturn L200 4 cyl Two Wheel Drive Automatic 117788 miles
I recently changed my fuel injectors to correct an rough idling problem. I used a chilton manual and since I replaced them I cannot get fuel pressure and fuel into the cylinders. I have check the fuel pump and it is pumping fuel and the fuel rail is also receiving fuel but no fuel pressure is building up. I have bled the system to my best ability but I cannot figure out what the problem is and I am hoping that you have some suggestions.[/quote:11e69e56d3]
Have you checked the fual pressure? Check out link below for video on how to test fuel pressure and fruel pressure regulator...
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Also have you checked the fuses and relays and did you double check that the injector harnesses are on correctly.
Mar 8, 2009 at 11:52 AM
