2003 Saturn L200 Gas leak
141,670 MILES • 4 CYL • FWD • AUTOMATIC
JOSEPH GEORGE
I have a strong gas smell coming from my vehicle. There is a leak that looks like its coming from the fuel tank. I need to find a diagram showing where the hoses run under and around the tank.
Aug 16, 2010 at 2:45 AM
SATURNTECH9
  • 30,869 POSTS
The hose's just run straight to the fuel pump module.If the gas is dripping down the tank then most likely it's coming from the nipple at the fuel pump module where the fuel pressure line come's off.If it's dripping from the top of the tank down you will have to drop the gas tank.
Aug 16, 2010 at 5:33 AM
