2002 Saturn L200 window motor
KRNASH
Interior problem
2002 Saturn L200 4 cyl Front Wheel Drive Automatic 108k miles
Need instructions on replacing the driver's side, front
window motor.
Thanks, krnash
Jan 26, 2010 at 8:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Removal & Installation
Window Motor & Regulator
Raise the window to the full UP position.
Remove the upper trim panel.
Remove the manual window regulator handle, if equipped.
Remove the power door lock switch, if equipped.
Remove the pull cup assembly.
Remove the door trim push-in retainers.
Remove the screw from the trim panel.
Pull the bottom of the door trim out to disengage the clips.
Lift up on the door trim panel to disengage the inner belt molding from the door flange.
Remove the door trim panel.
Remove the radio speaker.
Remove the front door water deflector.
Disengage the door glass to the regulator sash channel clips. Separate the door glass from the sash channel.
Push the window to the up position and tape in place.
Loosen the power window regulator bolts.
Remove the rear regulator bolt.
Lift the window regulator, disengaging the loosened bolts from the door.
Disconnect the regulator electrical connector.
Remove the power window regulator from the door.
To install:
Installation is the reverse of removal.
Jan 26, 2010 at 8:16 AM
