2002 Saturn L200 Wheel bearings
SCOTTHIA2000
Tires and Wheels problem
2002 Saturn L200 4 cyl Front Wheel Drive Automatic
How do you know that your front wheel bearings need replaced? If bad, can they be repaired instead of replaced? Can you replace just one or should both need replaced?
Oct 21, 2010 at 4:43 AM
SATURNTECH9
  • 30,869 POSTS
Does it sound like it's coming from the front or back?If it's the front you will have to press in a new bearing if it's the back you will have to replace the hub assembly.I would only replace the bearing that is bad.Do you have a jack and jack stand's?
Oct 21, 2010 at 4:56 AM
