2002 Saturn L200 vibration
XTCGODDEZZ
Other Category problem
2002 Saturn L200 Engine Size 4 cyl Wheel Drive Type unknown Automatic 107025 miles
My car is vibrating when stopped at red light and then just cuts off. I've had the idle control valve replaced. I've driven the car for 2 weeks with no problems then the vibration started again. When it starts vibrating and I put it in park the engine sounds like its reving even when the gas is not being touched. also getting an EVAP code. Changed spark plugs ,gas cap catalyctic converter, and added new tires. :cry:
Feb 2, 2008 at 7:46 AM
  • 75,988 POSTS
Have the idle air control valve and EGR checked for a start then follow it with a fuel pressure check.
Feb 2, 2008 at 8:00 AM
