2002 Saturn L200 Not sure of Problem Category
JJ1CABSR
2002 Saturn L200 4 cyl Two Wheel Drive Automatic
I cannot turn the key. I've tried the usual things, like turning the wheel back and forth and the key still will not turn to crank the engine.
What can the problem be?
Mar 23, 2009 at 3:10 AM
GRANGER_171
you will need to replace ignition switch had the same problem with my car the problem is you will have to get car in acc position to get switch out
Jun 18, 2009 at 8:16 AM
