2002 Saturn L200 Low Pedal
MLC173
Brakes problem
2002 Saturn L200 6 cyl Two Wheel Drive Automatic
We replaced pads and rotors on front and now it has a low pedal. Brakes are good but pedal is low, what can we do to fix this?
Apr 25, 2010 at 10:04 PM
  • 31,937 POSTS
Hi there,
Have you tried a re bleed, and does the pedal pump up? you can also try clamping of both front brake hoses and rear hose, if the pedal is still low i would be looking at the master cyl.
mark (mhpautos)
Apr 25, 2010 at 11:01 PM
