2002 Saturn L200 keyless entry
2002 SATURN L200
110,000 MILES • 4 CYL • FWD • AUTOMATIC
STEVE HELTON
I have 2 keyless entry remotes that have worked since the car was new.Neither will lock or unlock the doors or the trunk.I've tried unhooking battery terminal that didn't work.I've tried reprogramming according to the owners manual that didn'twork.The doorlocks will work manually with the button in the car and the trunk will open with button in car but.I've changed batteries in both but neither will work.Is there a fuse or relay that i should check.
Jun 26, 2010 at 6:56 AM
SATURNTECH9
  • 30,869 POSTS
Try taking apart the remote's and taking the circuit board out then take a tissue and clean the contacts on the board and the inside of the button's where they meet the contact's.Then try reseting them give that a shot.
Jun 26, 2010 at 10:53 AM
