2002 Saturn L200 ignition misfire
2002 SATURN L200
125,000 MILES • 4 CYL • FWD • AUTOMATIC
MJV2932
Code said it is an ignition misfire so I pulled the ignition coil and the spark plugs and tested it the two middle one will not fire so I got a new ignition coil and still have the same problem.
Oct 27, 2008 at 3:25 PM
  • CAR REPAIR CONTRIBUTOR
Hi mjv2932 and welcome to 2carpros
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Oct 27, 2008 at 3:35 PM
