The passenger side floor board is getting really wet from condensate leaking inside
Jul 22, 2010 at 1:13 AM
SATURNTECH9
✓Experienced Mechanic
Sounds like you have a clogged a/c drain look on your firewall about half way down towards the middle you will see a tube.There's a bolt holding it in remove the bolt and then remove the drain tube then clean it and put it back in.
