2002 Saturn L200
SASTURM
  • 2002 SATURN L200
2002 Saturn L200 4 cyl
My 2002 Saturn starts and shuts off. What is the problem?
Tuesday, May 18th, 2010 AT 11:59 AM
SATURNTECH9
  • 30,869 POSTS
I need a little more information then that like it does this when its hot or cold?Will it run at all or does it just start and run for a couple of seconds then just die?Or does it run for a while then do the not starting?The more details the better let me know.
Tuesday, May 18th, 2010 AT 2:55 PM
SASTURM
It starts and runs for a couple seconds. The shifter will not come out of park. It's like the security system has it locked up or something. The keyless entry remote no long works. All this stuff happened at the same time.
Wednesday, May 19th, 2010 AT 12:35 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like you have a bad body control module real common for that model have seen alot of them go bad. It controls your park lock solindo keyless entry and power door locks. Your fuel gauge all your inside lights. Your security system and the new module has to be programed by the dealer or a gm dealer. You will have to have it checked out by a professionial though I have a tester body control modules for 2000-2004 L model cars v6 and 4cyl for diagnosing. Each year and engine takes a differnt one so that will give you a idea on how common it is for them to fail since a have complete collection of bad ones for testing. Let me know what they find.
Wednesday, May 19th, 2010 AT 2:19 PM
