My car been shaking bad in when I turn the heat on?
NIKKIGINN12
  • 2002 SATURN L200
  • 4 CYL
  • 134,678 MILES
My car been shaking bad in when I turn the heat on I acts like it want to die on me and when I drive it it shakes really bad I put new plug in it help a little not much can you help me I dont know what it is
Saturday, January 16th, 2010 AT 10:47 PM
BASSTECH
  • 236 POSTS
Not sure if you mean the whole car shakes or the engine. If it's the engine, and also has a loss of power associated with it, it could be the ignition module that sits on top of the spark plugs. Also could have the check engine light on and you may hear the cooling fans running also when the car is not warm. I could use a little more info if you can.
Friday, February 12th, 2010 AT 6:11 PM
FLORIO65
Hello, what you just explained in the last part of your paragraph is what's happening to me. 5 months ago I replaced the spark plugs ignition coil and the ignition module on my 2002 Saturn l200 what you explain with the cooling fan is what's happening and it's still losing power and it's shutting off occasionally while driving the service engine soon was on but it's not anymore and the car still has hardly any power
Saturday, June 10th, 2023 AT 4:06 PM
  • 109,896 POSTS
The post you mentioned was never completed, so I can't say what happened with that specific vehicle. However, let's see if we can get you taken care of.
If I understand correctly, when the cooling fan turns on, you lose power, correct? What is the engine RPM at idle and in gear? Have you checked the idle air control valve? Does this only happen when it is at idle?
Saturday, June 10th, 2023 AT 8:33 PM
FLORIO65
When I start the car it idles at a little under $2,000 RPMs then settles down to about a little bit under a thousand RPMs the engine light was coming on it has loss of power and the cooling fan is coming on 30 seconds after I start it is the timing chain bad because I already replaced spark plugs coil pack and ignition control module.
Saturday, June 10th, 2023 AT 8:36 PM
  • 109,896 POSTS
If you have power loss, it leads me to think it could be a partially clogged catalytic converter. Do me a favor and look through this link. See if things mirror what you experience.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Sunday, June 11th, 2023 AT 4:31 PM
