2001 Saturn L200 Leaking Engine coolant within cab.
2001 SATURN L200
91,000 MILES • 4 CYL • 2WD • AUTOMATIC
IAMRICO00
  • 5 POSTS
Ive had this problem for a little while, but at random times, it seems that most to all of my engine coolant leaks onto the floor board of the passanger side. It floods the carpet with fluid. It only occurs on the passenger side upfront and it leaks pretty good. When I took it in to check it out, it doesnt seem to leak. A pressure cap was placed onto the engine coolant container within the engine to force a leak but still nothing. Because the leak seems to start on the right side of the floor bed toward the door I think it may be coming from underneath the carpet. There is no obvious trail of the fluid following it to any parts. Thanks
-Rico-
Jan 18, 2008 at 8:44 AM
MASTERTECHTIM
  • 4,750 POSTS
its cut and dry. you have a leaking heater core. that is the only thing it can be. hope this helps. feedback and votes are greatly appreciated
Jan 18, 2008 at 8:47 AM
IAMRICO00
  • 5 POSTS
Thanks, that was a pretty quick response. I guess the next question is... how do I go about fixing it? Can i do it myself? What would the cost of it be? Thanks.
-Rico-
Jan 18, 2008 at 8:54 AM
MASTERTECHTIM
  • 4,750 POSTS
im at home so i dont have access to my shop data base, so i cant give you estimate because it might be way off. if you still need a answer, tomorrow repost on this post and i will look up the info for you. hope this helps, feedback points and votes are always appreciated.
Jan 18, 2008 at 8:57 AM
IAMRICO00
  • 5 POSTS
Checkin in on the cost of a replacement on that part. Thanks again guy.
-Rico-
Jan 19, 2008 at 4:46 AM
MASTERTECHTIM
  • 4,750 POSTS
sorry i only work half days on saturday and its 2 pm in boston, sorry
Jan 19, 2008 at 4:48 AM
IAMRICO00
  • 5 POSTS
One more try... also, if you could, give me a source or two for purchasing or getting this problem taken care of. Thanks.
-Rico-
Jan 22, 2008 at 12:48 AM
MASTERTECHTIM
  • 4,750 POSTS
OK I JUST LOOKED IT UP. THIS MUST BEA A REAL EASY JOB. IT ONLY PAYS 1.4 HOURS AND YOUR PROVE ON PART WILL VERY DRASTICALLY FROM DEALER OF ABOUT 215 TO AFTERMARKET OF ANYWHERE FROM 50 AND HIGHER. ANY PARTS STORE WILL HAVE PART. HOPE THIS HELPS
Jan 22, 2008 at 1:05 AM
IAMRICO00
  • 5 POSTS
Thank you so much, youve been a tremendous help.
++++ Feedback!!!
-Rico-
Jan 22, 2008 at 3:25 AM
