2001 Saturn L200 Cranks, will not start, no spark
2001 SATURN L200
90,000 MILES • 4 CYL • FWD • AUTOMATIC
THEBIGDOG00
We have checked the alternator, battery and fuel pump. Replaced the ignition control module. Starts great and runs great when cold. After it gets hot if you turn it off and try to start it again it just cranks and cranks and we have no spark... ?
Thanks for your help!
-TBD
May 15, 2008 at 12:05 PM
THEBIGDOG00
coils - replaced both - no change
ignition control module - replaced - no change
spark plug wires - inspected - no problems
New symptom:
Car died while stopped at an intersection. Would not start till it cooled off.
Thanks,
-TBD
May 15, 2008 at 2:25 PM
BMRFIXIT
  • 19,053 POSTS
crank sensor should be check and replaced
try to get codes
May 15, 2008 at 2:33 PM
THEBIGDOG00
Had AutoZone check for codes - none
If the Crank Sensor were bad would it not have a an error code?
Thanks,
-TBD
May 15, 2008 at 3:12 PM
BMRFIXIT
  • 19,053 POSTS
not always
check for pending codes
check for RPM while cranking(you need a scanner for this )
I would give the crank sensor a test use an ohm meter or a ac volts meter
May 15, 2008 at 11:32 PM
THEBIGDOG00
it was the Crank Sensor!
Cost about $20 was easy to install but hard to reach, so it took about 30mins to find a way to get my hands around there. My little brother ended up being the one it finally snapped out for.
Thanks for your help.
-TBD
www.wesleyandteam.com
May 23, 2008 at 1:41 AM
