2001 Saturn L200 compressor
2001 SATURN L200
135,000 MILES • 6 CYL • FWD • AUTOMATIC
DSTUTLER
compressor is running , but warm air is all that comes ou the vent . Is the compressor not working or could it be something else ?
Apr 8, 2010 at 3:49 PM
CH112063
  • CERTIFIED EXPERT
  • 1,320 POSTS
Today all the systems run all the time. No more cycling clutches. You may have a problem with your expansion valve. It means you still have some pressure and freon, but either not enough, or maybe that valve is stuck, around a 300 dollar problem. You'll need to hook it up to an R134 machine to test it with the proper gauges. ok
Apr 8, 2010 at 9:12 PM
