2001 Saturn L200 Air Compressor will not turn on...Blower w
2001 SATURN L200
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
COUNTRYMEDIC
My compressor will not turn on. I have checked all fuses. I have also checked the level of refridgerant which is peak.
At the same time the compressor stopped kicking on , my mileage jumped and will not change and shows 641789. The trip meter will not even chance it stays at 0.0.
Another symptom is that the fan on the dash control works on high at minimum level and low at high level. Totally backwards.
I am thinking this could be a main computer problem but I am hoping you can tell me it is not... Any chance you have any advice?
Thanks in advance!
Aug 1, 2010 at 4:47 PM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.I have bad new's if your mileage jumped to 641789 then you have a bad body control module and it need's to be replaced first and see how thing's work.After you have it replaced if something doesn't work as it should i will help you figure out what else is wrong with your car.Pretty common for the L model saturn's to have a bad body control module.
Aug 1, 2010 at 5:36 PM
