Check freon ,fuses and relay and still doesn't work. Do you think it could be the compresor. Any other trouble shooting suggestions.
Jul 26, 2008 at 1:25 AM
MERLIN2021
✓Experienced Mechanic
did you check the R134a with a manifold gauge set? You need to have the gauge read approxiamatly 80 psi with a/c off for the low pressure switch to allow the compressor to run, what reading do you have?
Jul 26, 2008 at 1:33 AM
