2000 Saturn L200 key
99,650 MILES • 4 CYL • 2WD • AUTOMATIC
EPRITCHETT
My son has a Saturn that he added transmission fluid to, because it was not shifting, (I could not find a dip stick to check), and I noticed he spilled fluid all over, about 2 hours later after he drove the car around the cornor, he can get the ignition key to turn. I pulled the steering column covers and there looks like there is solenoid under the ignition cylinder. What is this and what drives it? Is it possible ther is fuse for this?
Thanks in advance
Oct 19, 2010 at 2:12 AM
SATURNTECH9
  • 30,869 POSTS
That solenoid keep's the key from turning off when the shifter is in gear.So what position is the key stuck in?Is it stuck in the lock position?
Oct 19, 2010 at 6:07 AM
EPRITCHETT
Thanks for responding, I pulled that solenoid off and figured out thaat it had to be like you said. The key is in the off position, just will not turn, never gave any hard to turn indications, just will not turn. I can not see how the steering wheel lock works, without pulling wheel, and I geuss that would be how you would change the ignition/cylinder assy.
Oct 19, 2010 at 10:19 AM
SATURNTECH9
  • 30,869 POSTS
You don't have to remove the steering wheel to replace the ignition cylinder.Remove the ignition bezel then tap lightly on the cylinder where you put the key in then see if the cylinder turn's if it does let me know and i will give you further instruction.
Oct 19, 2010 at 1:56 PM
EPRITCHETT
Thanks, that freed it up, I tried everything but the that, is there something sticking?, Like the lock tumblers?
Thanks
Emmett
Oct 20, 2010 at 2:26 AM
SATURNTECH9
  • 30,869 POSTS
Your going to have to change the ignition cylinder before it lock's up again if it stick's again and you can't free it up it's going to be a lot harder and more expensive to fix.Let me know when you get the new cylinder and i will give you further instruction's.
Oct 20, 2010 at 4:28 AM
