2000 Saturn L200 CHANGES GEARS WHEN ACCELERATE
89,600 MILES • 6 CYL • 4WD • AUTOMATIC
HENRIKA30
I have a 2000 saturn ls2, when I'm driving and I accelerate my transmission start to change gears from low gear back to regular gears. when i accelerate for speed it start to change back to low speed.
Feb 17, 2010 at 11:54 AM
2CARPRO JACK
  • 11,533 POSTS
Thoise transmisisons had all sorts of issues with the valve bodies inside them. Does the speedo work properly? You may want to start by having the PCM scanned for transmission related codes.They dont always set the check engine light, even though the computer has recorded a fault
Feb 18, 2010 at 12:17 AM
