Since the clock and radio resets then I belive it is not the starter or the relay, and probably a bad battery or corroded/loose connections.
May even be the ignition switch if it isnt the first two.
If it was the starter relay or a bad starter the radio/clock wouldnt reset!
SPONSORED LINKS
Monday, February 18th, 2008 AT 10:35 PM
