1997 Saturn L200 water leaking into the cabin
160,000 MILES • 4 CYL • FWD • AUTOMATIC
MSMELSY
I have water leaking into the drivers side cabin of my car. It doesn't smell like coolant (coolant levels are normal) and my widows don't fog up excessively. The heater works fine and the car temp does not fluctuate. I cannot trace the leak to my window or sunroof. Any ideas as to what's going on?
Feb 9, 2008 at 4:25 AM
VONWHO
I had the same problem and found that the drain for the AC was clogged. On the front of the firewall down low, you will a rubber boot. On mine the end of the boot was stuck closed. Rolling it between my fingers started the water running again.
Jul 15, 2009 at 10:37 AM
